Timing my 400
Farmall Kelly
02-07-2005 14:04:37
Well, I fixed a problem with my hydraulics, but had the pump on and off so many times that my distributor position changed making my timing way off. I don't see a timing mark. I have rotated a few times but battery died trying. What's the best way to start off atleast close?
Thanks in advance for the input.
CNKS
02-07-2005 14:45:27
 Re: Timing my 400 in reply to Farmall Kelly, 02-07-2005 14:04:37
The others are correct, but there about HAS to be a timing mark on the flywheel. I do have an M that is missing the pointer, though.
Nebraska Cowman
02-07-2005 14:12:03
just get number one piston at TDC on compression stroke and set the rotor to point to 2 o'clock. Points should be just starting to open.
Farmall Kelly
02-07-2005 14:24:45
 Re: Timing my 400 in reply to Nebraska Cowman, 02-07-2005 14:12:03
Thanks... that is what I was basically trying to do, but doesn"t the piston come up to expell exhaust one revolution and to fire the next? If so, how will I know which stroke is correct?
RustyFarmall
02-07-2005 17:30:22
 Re: Timing my 400 in reply to Farmall Kelly, 02-07-2005 14:24:45
The compression stroke should be much stronger. You should feel a definate difference.
kopeck
02-07-2005 14:32:04
Pull the #1 plug then put you thumb over the hole and feel for the compression stroke.
K
Nebraska Cowman
02-07-2005 14:31:14
stick your finger in the spark plug hole while turning it over, you should be able to feel the compression.
