OIl for liftall
R Wyler
02-08-2005 07:28:31
What type of oil should I use in my M Liftall? I used hydraulic oil in it before and it worked fine though I have read that 30wt non detergent is recomended. What is best? Thanks.
scubap58
02-08-2005 10:03:33
 Re: OIl for liftall in reply to R Wyler, 02-08-2005 07:28:31
If you use any of your hydralic attachments on any other tractors you will contaiminate their systems with 30wt.
CNKS
02-08-2005 07:48:42
You can use either one. It was designed for engine oil, that's what we always used (30 weight non detergent to prevent foaming), hytran had not been invented yet.
R Wyler
02-08-2005 07:51:33
 Re: OIl for liftall in reply to CNKS, 02-08-2005 07:48:42
Thanks for the info. I think I'll use 30wt not detergent. Though hyd trans problably would not hurt anything.
CNKS
02-08-2005 07:53:33
 Re: OIl for liftall in reply to R Wyler, 02-08-2005 07:51:33
It won't hurt anything, I just think 30W is just as good, Hytran is thinner, thus you have more of a chance of it leaking through the seals.
R Wyler
02-08-2005 07:55:43
 Re: OIl for liftall in reply to CNKS, 02-08-2005 07:53:33
I see how that could be a problem. I think I can get 30wt not deterg here in town that is what I'll get. I think it only holds 6 quarts.
