4cyl. international engine
Joe T.
02-08-2005 10:45:34
I bought a old frick sawmill. It came with a 4cyl. international gas powerplant. the numbers have been removed. It looks like maby the same as a H or M Farmall motor. is there any way I can tell what I have? thanks Joe.
CNKS
02-08-2005 11:21:00
 Re: 4cyl. international engine in reply to Joe T., 02-08-2005 10:45:34
A picture would help. An H or M will have plates on both sides of the block, the one on the right exposes the pushrod area, the one on the left is a water jacket cover. I believe this is true of the W9 also. I don't think the A,B,C, engine has any such covers. There should be a machined surface under the #1 spark plug that has a number -- the prefix to that number will be an indication. Also, there should be a part number cast into the block, that should still be there. If the block is off an F series, someone else will have to guess. The IH engines referred to have the dist or mag on the right, carb on the left.
Joe T.
02-08-2005 13:42:59
 Re: 4cyl. international engine in reply to CNKS, 02-08-2005 11:21:00
I checked the numbers where you said I foundthe ones by #1 plug. UBK M432.does that mean it is a M motor? I guess and are the numberw 43 the year? thanks a lot for your help.
Jim Becker
02-08-2005 20:44:20
 Re: 4cyl. international engine in reply to Joe T., 02-08-2005 13:42:59
Yes. The K means it is the same as an M. The M means it is a motor. Following the M should be the sequence number. There is probably a least one more digit you missed while reading it as the start number was probably 501.
