hyd system on farmal H
SHORTY
02-08-2005 14:30:59
I added a three point hitch kit on my H. Is there a kit so I can use the front end loader and the three point hitch at the same time? I"m changing hoses back and forth now.
Thanks Steve
Novel Idea Guy
02-09-2005 07:24:38
 Re: hyd system on farmal H in reply to SHORTY, 02-08-2005 14:30:59
Assuming you're using the stock one-way lift-all control, the easiest thing to do would be to plumb in a two-spool valve. Then you will have dual two-way hydraulic outlets, one for the loader, and one for the 3pt.
The "right" parts are tough to find, and expensive.
Randy SE-MN
02-09-2005 06:05:41
Just put a ball or globe valve in the hose(s) that go to the loader and turn them off when you only want the three-point active...Simple
dej(JED)
02-09-2005 05:48:46
Shorty, Buy a fill pipe double action tree. You unscrew the fill pipe cap and thread it on. Then run hoses, one to loader and the other to 3 point. I have one if you can't find one in your area.
RandyNark
02-08-2005 20:54:14
Great looking and working H. With the 3point on this set up do you have down pressure. this could be quite useful if so.
Dave (IL)
02-08-2005 18:41:11
third party image
3 sets of two ways on this H. Lift, bucket, and remote.
Plumbs into the regular lift and the handle is tied open. Works very well considering.
That's a JD 45 loader - what a beast on the H.
Dave in CT
02-08-2005 19:36:11
 Re: hyd system on farmal H in reply to Dave (IL), 02-08-2005 18:41:11
I'm rebuilding a 45 to put on my H. How do you like it? Any tips?
Dave (IL)
02-08-2005 20:04:55
 Re: hyd system on farmal H in reply to Dave in CT, 02-08-2005 19:36:11
third party image
It's a beast! I bought it this way about 2 years ago. Gotta admit it's been very useful just lifting, moving stuff around, cleaning up the 3 acres. Hydraulics are a bit slow, but effective.
I did buy a 641 Ford with loader and mower to replace it last fall. It's a real effort mowing with dead PTO and that bucket hanging out there.
CNKS
02-08-2005 18:02:11
A simple 2-lever/outlet spool valve will work.
gene b
02-08-2005 16:20:32
I want to see you drive and use three pt and loader at same time which hand will be on the wheel?
riverbend
02-08-2005 15:38:12
I bought a hydraulic 'switch' for mine, one inlet, two outlets. Up is the loader or the line to the back. Down is for the three point. It was made by Cross, but I would have to take it off to look for a part number.
