block casting number D282
farmalls4me
02-08-2005 18:02:46
I have located a couple of numbers on the block of my D282 in a 656 tractor. Which is the casting number? I assumed the 67523 was the engine serial#. It is stamped on a machined surface on the left side of the block. The casting number is what I'm trying to determine. Thanks All!
hector gemme
02-11-2005 08:14:19
 Re: block casting number D282 in reply to farmalls4me, 02-08-2005 18:02:46
HI I HAVE ON 282 INT BLOCK 6 CYLINDRE DIESEL
Yellott Canby
02-08-2005 20:22:56
Hello, I had a similar question on this forum earlier today. I believe the casting # is a raised number probably around seven digits with an R something after it. On the D239 it is supposed to be on the left side center toward the top, just below the water jacket. My 674 had no casting # at all. I hope this helps. Good luck. YC
