Carb needle and seat valve
r4etired
02-09-2005 03:15:03
Anyone else having trouble with the neoprene top needle valves. I have rebuilt many carbs on farmalls over the last 30 years and since I cannot find the solid needle valves I,m getting a few dripping carbs. I rebuilt one for a friend last weekend. it doesn't leak bad but just stays wet on the bottom and will drip maybe two drips an hour. Anyone know a supplier for the old style needle valves for farmalls
riverbend
02-09-2005 06:07:06
 Re: Carb needle and seat valve in reply to r4etired, 02-09-2005 03:15:03
I have had trouble with the needles and seats in the aftermarket kits leaking, but the ones for the IH dealer have been good.
Slappy
02-09-2005 04:18:36
I'm not sure of all models but the Cub and H kits from the dealer come with steel needles. Although the needle from the dealer leaked on my Cub and I went with a vicon tipped needle from Krohler and it solved the problem. You might find that the needle is not the problem. First, be sure the float adjustment is correct. I also found that the needle cage and/or main jet threads are a source of slow leaks like you describe. Permatex Hi-Temp thread sealer takes care of that.
