hammer mill grinder plates
Chuck Kaufman
02-09-2005 12:26:51
The neighbor needs two grinder plates for his hammer mill Any hints on where to look? Thanks Chuck
El Toro
02-10-2005 08:18:00
 Re: hammer mill grinder plates in reply to Chuck Kaufman, 02-09-2005 12:26:51
Hi Chuck, If you can not find any replacement
plates, you can probably remove them and have a machine shop fabricate some from the old plates.
They can probably harden them too after they finish the machining and drilling. Hal
I Bleed Green
02-09-2005 18:35:03
I bet its a burr mill.
Haas
02-09-2005 13:22:51
I wonder if you are talking about a hammermill or a McCormick feed grinder. The hammermill has swinging hammers in it and the feed grinder has the plates. The plate type feed grinders came in 6, 8 and 10 inch sizes I believe. I've seen some parts for these a the Red Power Roundup vendor area. I suggest you put an ad in the classifieds here and maybe you will get a response. Also, if you are not aware, the plates are reverseable. That is both sides have the "teeth" on them and you can just take them off the rotor and turn them over. In your ad, be specific as to size you need, also there were many different kinds of the plates depending on the application. I have an 8 inch type B McCormick grinder. No extra plates though.
