oil cooler
Terry Haith
02-09-2005 14:16:56
do oil lines go into the radiator for cooling oil in the 560 farmall? we are getting oil into the radiator but not into the oilpan Thanks Terry
ejr-IA.
02-09-2005 19:31:20
 Re: oil cooler in reply to Terry Haith, 02-09-2005 14:16:56
Left side under oil filter canister between frame and engine block has two hoses attached to it.For ease of working on it I take the left side frame rail off.You must support the tractor with blocks or jacks.
RAS
02-09-2005 15:35:04
Your engine oil cooler is bad.
Terry Haith
02-09-2005 16:38:47
 Re: oil cooler in reply to RAS, 02-09-2005 15:35:04
were is the oil cooler located?
