farmall m rebuild kit- which one?
tim bynum
02-10-2005 05:12:33
im in need of a rebuild kit for my farmall m.serial number fbk 259241 xi im looking at the kits on this web site but i can not figure out what is ment by steped head. the head on my m does have a step to it but the top of my pistons are flat.can some one with experiance give me some help? thanks, tim
Bob from IL
02-10-2005 15:55:30
 Re: farmall m rebuild kit- which one? in reply to tim bynum, 02-10-2005 05:12:33
Also what size bore are you looking for. Most M'S are 4" bore instead of the origional 3-7/8" bore. Larger pistons-thinner sleeves.
randy hall
02-10-2005 09:14:55
if you would be interested i can get you american made firecrater pistons and sleeve kits at a good price.
captaink
02-10-2005 07:55:01
The stepped head pistons will increase the compression, and power, but require more effort to start the engine. If you still are running a 6-volt system, it will need to be in good to excellent condition to start in the winter. (Heavy cables, clean connections, etc, etc…) A 12-volt system will be more forgiving to corroded terminals etc. I would go with the stepped pistons, unless you never need any more power than you had and you can save money.
Tailhunter
02-10-2005 07:22:56
Stepped head pistons will increase your compression...thus increasing HP some. The compression is rather low on a lot of these old tractors...allowing you to use a lesser grade of fuel. If you are going to change out pistons anyway, go ahead and use the stepped ones..compression will still be low enough for regular unleaded gas.
Forklift
02-10-2005 05:57:27
That usally means if you want flst head pistons or stephead Pistons. Stephead Is High dome.
forklift
02-10-2005 05:59:22
 Re: farmall m rebuild kit- which one? in reply to Forklift, 02-10-2005 05:57:27
Sorry, FLAT Head Pistons Not Flst Head.
