clutch housing and crankshaft end
johnsoncb_550
02-10-2005 10:26:08
I have a Farmall H and i recently pulled the motor off and I can't get clutch housing of the end of the crankshaft. is there some kind of secret? thanks for your help Jordan.
Aces
02-10-2005 15:12:05
 Re: clutch housing and crankshaft end in reply to johnsoncb_550, 02-10-2005 10:26:08
Don't understand question if you got the motor pulled then the clutch housing must be off the motor. Or did you pull the motor and clutch housing off the rear end housing. The clutch housing and motor has 3 or 4 hex cap screws in from the front through the side rails and 2 hex head cap screws in from the back that go into the back of the block, if I remember right you have to have the starter off and go through the starter hole to get at the one from the back. Some one can correct me on this if I am wrong. Don't know if this helps any.
riverbend
02-10-2005 15:08:39
What I think you want to know is that there is a dowel pin that locates the flywheel on the end of the crank.
johnsoncb_550
02-10-2005 18:50:38
 Re: clutch housing and crankshaft end in reply to riverbend, 02-10-2005 15:08:39
Thanks for the info. I wasn"t sure if there was a dowel pin or key on the crankshaft. I am sure it will come off a lot easier now.
