Paint Remover
Allan in NE
02-10-2005 17:10:06
Howdy,
I've seen these round, high speed wire brushes for angle grinders hangin' on the wall in stores for years, so I finally broke down and picked one up today.
Say now, these little fellers really get after the program! :>)
Allan
third party image
KyTed
02-11-2005 10:06:52
 Re: Paint Remover in reply to Allan in NE, 02-10-2005 17:10:06
Those high speed grinders and wire brushes are great, safety glasses are a good idea but dont forget a good resoirator that old paint is lead base.
scotty
02-11-2005 04:41:08
Mornin Allan, Thats the setup that I use. Ive got the Dewalt right angle grinder and you can switch the handle from side to side. One other tip, if you can find them, try and find the twisted or braided brush they hold up much better than what youve got on there now! Same size, just braided!
scotty
JOSSETTE
02-10-2005 19:42:01
I use Zip-Strip- Industrial strenth paint remover. brush it on and watch it fall off. use the wire brush very little. use a damp cloth to wipe it down.
Novel Idea Guy
02-11-2005 12:56:23
 Re: Paint Remover in reply to JOSSETTE, 02-10-2005 19:42:01
Where do you get "Zip Strip?" I've seen them use similar stuff to strip cars on TV.
JOSSETTE
02-11-2005 15:35:07
 Re: Paint Remover in reply to Novel Idea Guy, 02-11-2005 12:56:23
star bronze co. bow 2206, alliance ohio, 44601
1-800-321-9870.
it says it is garrented to get 5 coats off in one coat. i took at least that many off my 400. lot faster that that spinning wheel
JOSSETTE
02-11-2005 15:28:31
The local hardware store has it. I believe it is a BEST do it yourself hardware or something. has an orange bag with BEST on it. do not get it on your hands or watch it peal off too.
Gordo
02-10-2005 19:30:46
I use those new "flap wheels" the 5 inch on a 5 inch Makita. Much faster than wire. But the wire is good for high concabe/convex areas. But why not go to the 71/2 inch body shop grinder with a 4 inch brush?
Gordo
CNKS
02-10-2005 18:53:24
Yeah, wait until you lay on your back underneath the tractor, and try to remove the paint/rust -- I usually vibrate for a couple of days afterward.
FRANK
02-10-2005 18:59:18
 Re: Paint Remover in reply to CNKS, 02-10-2005 18:53:24
YOU ARE RIGHT. THEY DO WORK. JUST MAKE SURE THAT THE BRUSHES THAT YOU BUY WILL TAKE THE RPM,S.I USE AIR GRINDERS THAT TURN UP AROUND 28,000 RPM,S AND YOU DON,T HAVE A HIGH SPEED WHEEL, THE WIRES WILL COME OUT. THE BEST I HAVE FOUND ARE AT GRAINGERS. THEY ARE A LITTLE MORE EXPENSIVE, BUT THEY LAST A LONG TIME.
Dixieland
02-10-2005 17:54:05
You caint beat dat wid uh stick!!!
Bugsy
02-10-2005 18:59:01
 Re: Paint Remover in reply to Dixieland, 02-10-2005 17:54:05
Allan, I would probably fire up the sand blaster for a job like that but when it's 10 below that little tool would be handy. How much does it cost and how long will it last. Bugsy.
Allan in NE
02-10-2005 18:09:44
Well Yeah,
'Cause up until today, I've been using this hi-tech outfit. :>)
Allan
third party image
CLIFF
02-10-2005 18:51:47
 Re: Paint Remover in reply to Allan in NE, 02-10-2005 18:09:44
Somehow you still need both
Dixieland
02-10-2005 18:49:59
Always good to upgrade. I got me a Scat-Blaster back a few months ago and finally got around to settin it up today. WOW! what a difference. Just for fun I blasted a manifold and was really surprised. an I did'nt even get tarred.
tommy w
02-10-2005 19:26:08
 Re: Paint Remover in reply to Dixieland, 02-10-2005 18:49:59
they do work good ,but wear some safety glasses with the wire wheel.
