Implements with an International 460
JCH
02-11-2005 18:08:45
Looking to buy a 460 but would like to know how well these tractors do against an 800lbs round bale. Has anyone used this tractor to move round bales with a bale spike attached to the 3-point hitch?
How well does it pull a small 5 foot no till drill?
r4etired
02-11-2005 18:20:20
 Re: Implements with an International 460 in reply to JCH, 02-11-2005 18:08:45
A couple of front weights and the 800lb bale will work. but don't latch on to 1600lb or you will be watching the clouds, Should handle the drill Ok
CNKS
02-11-2005 18:18:56
I don't think 800 lbs is much for the hydraulics, except that you have all the weight to the rear -- I have never messed with bales, so I can't answer further, but you might need the front weighted pretty good. 5 ft no-till drill? Unless they are VERY heavy, it can pull 2 to 4 of those, depending on the design, how deep you pull it and how hard the ground is.
