IHC feed grinder Plates
Chuck Kaufman
02-12-2005 17:22:30
Neighbor just tore up the plates in his feed grind .No Luck at dealer Part#229F 4 3/8 ID 6 3/8 OD Anybody know where to look? Thanks Chuck K.
Lance R.
02-12-2005 21:17:05
 Re: IHC feed grinder Plates in reply to Chuck Kaufman, 02-12-2005 17:22:30
If this is a grinder/mixer that needs screens you might be able to get them from Artsway since they manufatured them for IH. You can reach them at their website which I think is Artsway.com. If they don't have it I'll bet they can make one for you.
Jim in Michigan
02-12-2005 19:13:51
Well if it was for a hammer mill I could help,, I have a nice one for sale, ,,,Jim
El Toro
02-12-2005 19:04:29
Hi Chuck, I would go with what the Cowman recommends on having them made and have that hard facing welded on them. I have it put on my tiller tines to cut down on the wear. Hal
Nebraska Cowman
02-12-2005 17:48:39
here's my suggestion. have a machine shop make them out of steel plate. then use hard surface weld to build ridges on them. I told this to a man the other night and he said that they have an abasive weld that he thought might work real good. I forget what he called it, something they use on horseshoes I think.
