300 hydraulic pump on H
zooeyhall
02-12-2005 18:16:39
Just a quick question, will a 300 hydraulic pump fit on a regular H? This is the pump that goes between the distributor and timing case cover. I have been told it will if you modify the holes on the pump somewhat.
Thanks for any advice!
dej(JED)
02-14-2005 06:12:37
 Re: 300 hydraulic pump on H in reply to zooeyhall, 02-12-2005 18:16:39
You will have to enlarge one of the 2 mounting holes a little. Everthing else, the gearing that is, will mate up. Some of the last H's had the newer style front covers and the pump will bolt up directly without any mods.
zooeyhall
02-14-2005 07:16:00
 Re: 300 hydraulic pump on H in reply to dej(JED), 02-14-2005 06:12:37
Thanks for the advice. After I did this post, I discovered how to use the archive search feature. That also helped me to find alot of info for this question from previous posts.
