M Farmall Throttle lever
budbud
02-12-2005 19:29:49
I have a 1949 M Farmall tractor. The throttle lever is on the top of the steering column as opposed to being on the side like most M's. Any reply would be helpful if the top mount throttle lever was an update or a factory original. thanks.
John M
02-13-2005 11:14:01
 Re: M Farmall Throttle lever in reply to budbud, 02-12-2005 19:29:49
Im thinking you have a cotton picker M.The throttle handle,tyhe part you acually move sits straight up on the picker set up.Maybe what you have hasnt been changed to the normal sidewyas type.
Novel Idea Guy
02-13-2005 06:58:36
Could you point us to a picture of this "on the side" throttle arrangement? Maybe we're thinking of two completely different things here.
Brianbws
02-12-2005 22:14:35
My Super M is on top, Super C on side. You can pick up a new MW style for on top of the steering shaft at TSC.
David B
02-12-2005 20:46:30
Is it an M diesel? I guess you could say the throttle on them is kinda on the side.
CNKS
02-12-2005 19:57:24
Factory original, never seen an H or M with the throttle you describe, only the A,B,C,etc series.
TDK
02-12-2005 19:46:40
All the M's I've seen, throttle was on top. Same as the H.
MeAnthony
02-12-2005 19:44:10
My M is a '44, and it's on top too.
Joe from Tn
02-12-2005 19:32:18
Throttles on top on H's. Don't know if this will help or not.
