In need of hyd. assist for clutch??
Larry W.
02-12-2005 20:14:05
Hi guys! I'm hunting for a hydraulic clutch assist that will fit an 856. I need the lines, cylinder, etc, the whole kit. If you have one, or any ideas, it would really be appreciated, thanks!!
leland
02-13-2005 07:22:07
 Re: In need of hyd. assist for clutch?? in reply to Larry W., 02-12-2005 20:14:05
If your needing this bacause of a handicap contact the Uof I in champain ILL they have been designing quite a bit of stuff for the disabled farmer
the tractor vet
02-13-2005 07:13:10
What kind of clutch did ya install in a 856 that you need hdy asst., i have installed a bunch of hd pressure plates and until you get into the 10 -14's never seen one that was that bad that you needed that .
Novel Idea Guy
02-13-2005 06:54:03
Good luck. These are fairly rare, in high demand. For the most part, they were only installed on SOME of the '66 series tractors. That translates to EX-PEN-SIVE. My Dad's been looking for one for the 756. The mechanic who put the diesel engine in it also installed a 966 clutch, not exactly an easy-pushing clutch for loader work.
I've been trying to come up with an alternative system, something like a Char-Lynn power steering assist on an M, except linear, that we could make brackets for, and bolt on.
MN Scott
02-12-2005 20:33:54
Try posting a add in the classified section, you will get more offers. Also try your local salvage yards, most sell these as kits
