charlynn power steering pluming off live hyd. ques
drgw3101
02-12-2005 23:30:36
hello, i plan to run charlynn p/s off the ih live pump on my super m..i an not running any hyd. inplements off the hyd. unit,ports are going to be pluged with pipe plugs,can i tie into the pressure and return hoses at the resivior and run without a diverter/safety valve? thanks all...
Bob M
02-13-2005 08:10:42
 Re: charlynn power steering pluming off live hyd. in reply to drgw3101, 02-12-2005 23:30:36
DRGW - You still need a flow divider and relief valve!
The SM live pump is good for 12 gallons per minute; the Charlynn only needs 2 gpm or so. The excess flow will bypass thru the relief valve (if you"ve got one) which loads up the pump and will very quickly overheat the hyd system. Of if you don"t have a relief valve SOMETHING is gonna break (hyd line, steering motor, cam drive gear, etc)
Novel Idea Guy
02-13-2005 06:42:04
If you just tap into the pressure line before it gets back to the reservoir, you won't have any power steering. When the valve on the reservoir is in the forward position, there's no pressure. The pump is dumping the fluid straight back into the reservoir. You would still need a diverter.
