Need advice on pulling cylinders on my 1941 Inter
MACE
02-13-2005 08:21:05
Help...!
I have made a makeshift puller and pulled one of the cylinders out of a C113 engine. It was tough, but I was able to get it out. The reason I pulled it was due to a deep score mark down the length of the cylinder wall. I have decided to replace the other 3 cylinders as well. What is the most effective way to get these cylinders out? I am having a difficult time with the next one. It doesn"t want to budge. Any help or advice would be appreciated.
Thanks,
MACE
justin w
02-13-2005 13:00:15
 Re: Need advice on pulling cylinders on my 1941 I in reply to MACE, 02-13-2005 08:21:05
I have always used a post and hammer to remove the wet sleeves in the C113 & 123 engines. If the sleeves are really tight, I have used a steel plate & bar welded together. Just remember that you only need to move the sleeves about 3" up, and then they will be loose.
Dixieland
02-13-2005 11:03:52
Hi Mace. Someone else asked about getting old sleeves out the other day. I directed them to the one for sale on ebay which is a very heavy duty and solid tool for removing 3" wet sleeves. The pulling plate is 5/8" thick so I don't think you would ever break or bend it. It is also designed for in-frame use if need be. Take a look at it and you may be able to figure out how to build your own but the materials look pretty expensive. Good luck
MACE
02-13-2005 11:43:05
 Re: Need advice on pulling cylinders on my 1941 I in reply to Dixieland, 02-13-2005 11:03:52
After posting this question, I went back to the tractor and made some improvements to my makeshift puller. I have pulled all but one sleeve out. Thank you for the response to my questions?
MACE
Allan in NE
02-13-2005 09:28:41
Hi Mace,
Take your welder and run a couple of vertical beads up the inside of the sleeves. That will "shrink" 'em.
Allan
