Clutch Drain
PAULIH300
02-13-2005 18:50:15
Question:Is there a "drain" for the clutch area in the event of a seal leak on a 300U? Some sort of removable pipe plug? Whenever I get ready to change the gearbox fluid,I would feel a lot better if there was some way to tell if it leaks or its still solid.
TDK
02-13-2005 20:52:23
 Re: Clutch Drain in reply to PAULIH300, 02-13-2005 18:50:15
There is no drain, but the clutch housing cover can be removed for the same purpose. It's the front cover on bottom of clutch housing, held on by two bolts.
