Farmall M with IH 10 speed?
puzzled
02-13-2005 18:51:31
I have a question for you guys out there. Has anybody ever heard of or seen a IH 10 speed M? I know of a Farmall M with this so called 10 speed. I have heard of many m@w 9 speeds but never a ten speed.
The tractor can be in high and low through every single gear-first thru 5 and also reverse. I am not sure what the difference is between the 9 speed. The guy claims it is orginal from IH and is asking $6000 for the M.
Just wondering if anybody has seen this or heard of this-maybe it is just a 9 speed and this guy is blowing smoke.
Thanks
CNKS
02-13-2005 19:19:50
 Re: Farmall M with IH 10 speed? in reply to puzzled, 02-13-2005 18:51:31
The only possibility is that the "M" is a Super MTA with torque amplifier, that is indeed a 10 speed, and if the tractor is in excellent condition, $6000 may not be out of line. If it is an M, then you shouldn't be able to see the guy for the smoke. And not worth anyway near $6000.
puzzled
02-13-2005 19:54:32
 Re: Farmall M with IH 10 speed? in reply to CNKS, 02-13-2005 19:19:50
No, it is not a MTA. Straight 1947 (I believe) Farmall M. He is just out of line. Or maybe he doesnt know about it himself.
Novel Idea Guy
02-14-2005 04:56:16
 Re: Farmall M with IH 10 speed? in reply to puzzled, 02-13-2005 19:54:32
Have you had a chance to look at the tractor? What does the "high/low" shifter look like? If it's a long lever on the left side of the operator's platform with a squeeze handle, it's an MTA. But, I'm guessing you know the difference already.
He may be blowing smoke up your butt, or he may just have a 9-speed that he embellishing the capabilities of.
puzzled
02-14-2005 19:30:38
 Re: Farmall M with IH 10 speed? in reply to Novel Idea Guy, 02-14-2005 04:56:16
No, the tractor is not a Super MTA. I have driven a MTA for years. This is a straight M. I lever for shifter between high and low sits on the right side of the tractor-near where your belly pump lever would be. The only thing is the linkage says M@W on it (noticed after a better look). I am thinking it is just a m@w 9 speed.
Thanks for the info though guys. Stuff like this bugs me-I try to keep up my knowledge on IH. Thought maybe they had some experimental deal out for a while.
