350 tranny oil looks like caramel sauce
joe in ct
02-14-2005 17:53:12
by the looks it hasnt been changed in a long time.seems water made a visit. big plug in rear had what seemed like dirt in its cap also only drained out about 3 to 4 gallons. could any harm have been done?
Bob M
02-15-2005 05:30:12
 Re: 350 tranny oil looks like caramel sauce in reply to joe in ct, 02-14-2005 17:53:12
You PROBABLY are OK.
A couple years ago I dropped the “oil” on a newly aquired ’47 Minnie Mo U. The stuff that came out looked like and had the consistency of chocolate pudding - it came out in chunks (took it several days to drain completely…) However dumping in a few gallons of diesel to help flush out the remainder of the old lube, then refilling with 13 gallons of fresh 80W-90 the transmission actually ran quieter. Found also the gear lever works easier too.
So I guess unless you got a large quantity of clear water first when you started to drain - which causes rusting of wetted bearings ‘n gears – your transmission is probably alright.
dhermesc
02-15-2005 05:51:15
 Re: 350 tranny oil looks like caramel sauce in reply to Bob M, 02-15-2005 05:30:12
If it was working OK when you drained it you're probably going to be OK - and count yourself lucky. The 3-4 gallons issue would cause me more concern the the color - the transmission was being operated with less then half amount of oil it should have in it. I'd definately do the diesel flush that Bob M spoke of.
