Seat mounting plate question
MM_TX
02-14-2005 19:34:17
Does anybody know if the seat assembly from a Super C is the same as a batery under seat Super M? The seat mounting plate # in SC cat is 355 750 R12. In the M cat (specal seat support & battery box) is 355 750 R11. The rest of the assembly parts are the same numbers. Thanks MM
Nebraska Cowman
02-14-2005 20:36:06
 Re: Seat mounting plate question in reply to MM_TX, 02-14-2005 19:34:17
probibly the only difference is the M seat is made to hinge and the C is bolted soild. I bet you could make it work.
