baking vs. hot tanking a H engine block
johnsoncb_550
02-15-2005 17:03:50
I have an farmall h motor with a lot of old grease and paint and surface rust on it. what would be the best way to clean it. Also what would the cost difference be.
El Toro
02-16-2005 09:24:07
 Re: baking vs. hot tanking a H engine block in reply to johnsoncb_550, 02-15-2005 17:03:50
They charge $45.00 in my area to do it. Makes it nice and clean to reassemble the engine. You can prime and paint too. Hal
randy hall
02-15-2005 20:30:45
around hear most all of the machine shops use the bake method because of the high cost of disposing of the caustic solution with the hot tank method. they both give the same result.
Allan in NE
02-15-2005 17:11:26
Hi John,
I don"t know what they charge at a machine shop, but you can"t bet much better than hot tankin".
Takes "er right down to the metal.
Allan
