farmall c carb leak
william pugh
02-15-2005 20:24:22
The Carb on my C wiii leak fuel out the bottom when I turn the gas on to start it. Once the tractor starts the steady dripping seems to quite. Wonder if the float was sticking or that was just the nature of the beast.
ds
02-15-2005 21:07:30
 Re: farmall c carb leak in reply to william pugh, 02-15-2005 20:24:22
yes they will drip usually after a cold start with full choke. if it starts dripping when you turn the gas on you have a float or needle problem
