Farmall A moving machine question
Mark A. McCall
02-16-2005 12:22:21
I now have a rear-mounted sickle mower for a Farmall A. I need several rock guards to get it going. I have several guards in the bucket of spare parts that came with the mower, but the ledger plates are worn smooth on all of them. I saw ledger plates advertized in a parts catalog, so I know that the guards can be rehabilitated. My question is: HOW DO I GET THE LEDGER PLATES ON? I figure I can drill the old rivets to get the worn out plates off, but, I can't figure out how to rivet the new plates on. Any help would be appreciated. Thanks!
KirkMn
02-17-2005 15:17:42
 Re: Farmall A moving machine question in reply to Mark A. McCall, 02-16-2005 12:22:21
The rivet is hard to see because that is the part of the guard that rides on the ground causing the rivet to wear smooth. Take a smaller drift punch and hit in the area where the rivet goes thru. Hope that helps.
Mark A. McCall
02-18-2005 05:05:04
 Re: Farmall A moving machine question in reply to KirkMn, 02-17-2005 15:17:42
Thanks! That makes sense!
res
02-16-2005 14:30:32
just insert your new rivet into ledger plate with rivet head in the recessed ledger hole,through the guard with new rivet,,have a good place to rest rivet head on and pean over the ""tail""? end of rivet. guard should be off of machine to do this .
MarkA. McCall
02-17-2005 09:19:40
 Re: Farmall A mowing machine question in reply to res, 02-16-2005 14:30:32
Thanks for the reply! All the guards are already off the mower, in a bucket - that is not a problem. I have an anvil to peen the rivets flat on - that's not a problem, either. However, the guards don't appear to have holes drilled all the way through to put rivets in - am I missing something? Maybe I need to look closer at the guards after I clean them up with a wire brush. Again, thanks.
