removing and unhooking a farmall h hydralic pump
jerry ahring
02-16-2005 17:26:07
I'am looking for help on removing and unhooking a hydralic pump for a Farmall H tractor.I was wanting to take this pump out so that i am able to replace the clutch that has become stuck from setting in the shed. Is there a possible way to remove this pump without splitting the tractor? any information to help me is welcome and greatly appreciated. thank you.
zooeyhall
02-17-2005 11:23:23
 Re: removing and unhooking a farmall h hydralic p in reply to jerry ahring, 02-16-2005 17:26:07
The repair manual from IT pub. has simple directions for making a pair of "T" handles, that fit into the slotted holes in the bottom of the pump. I have used these and they work great (it does take two people tho--one on each side). I have also used a automotive type transmission jack.
The pump is heavy, and is somewhat harder to get back in then out (aligning the filler pipe).
williamf
02-17-2005 04:45:48
It's not hard to get that pump out. But it is heavy. I've read a lot of different ways to do it on this site; I think the safest and least backstrain is the way Kelly C and I did, putting a cradle under it, supporting the cradle from above, lowering it (and raising it back) with complete control
Wm
Here's a link to Kelly C's pictures.
williamf
02-17-2005 04:49:21
 and a link to mine in reply to williamf, 02-17-2005 04:45:48
third party image
Looks like this:
Allan in NE
02-16-2005 17:28:14
Jerry,
The thing drops right out the bottom of that torque tube. Kinda heavy.
Allan
Ludwig in Pa
02-16-2005 17:48:00
 Re: removing and unhooking a farmall h hydralic p in reply to Allan in NE, 02-16-2005 17:28:14
You do not have to remove the pump to free the clutch. On my H there is a cover under the clutch. Remove the cover, take every other pressure plate to flywheel bolt out. There are 3 or 4 threaded holes in the pressure plate. Install the bolts in the threaded holes this takes the pressure off the clutch disc. I installed longer bolts in the remaining pressure plate bolts, this allowed me to pry off the clutch disc which on my tractor was stuck to the pressure plate. When I reassembled the bolts I had a wooden block to keep ressure off the clutch pedal. When I park the tractor I put in the block to keep pressure of the clutch. This has worked fine for years.
