farmall c flywheel cover
mark_w_mn
02-17-2005 03:45:23
I'm looking at a flywheel cover that is listed as being applicable to a Farmall A & B; will that same cover work for my C?
haas
02-17-2005 14:08:37
 Re: farmall c flywheel cover in reply to mark_w_mn, 02-17-2005 03:45:23
Two kinds of these covers, round and oval. Look at the hole in your clutch housing to tell which you need. I think A, B, C, etc are all the same except for the round versus oval situation.
Randy in NE
02-17-2005 04:28:24
If you are talking about the half-circle plate it is the same for the A/B and the C for serial numbers 501-69897. That is part # 8778DAX. For the C with serial number 69898 and up it is 354909R1.
