IH lights
Andre' Burnham
02-17-2005 06:38:31
Does anyone know where there is a website or a place to buy just the light bulb for the tear drop style light for farmalls. The housing and lens are fine but the bulb is blown. Can anyone help me out.
Gordo
02-18-2005 07:44:12
 Re: IH lights in reply to Andre' Burnham, 02-17-2005 06:38:31
Correct bulb is GE 1133. Available most shops, or order a few. They are in current production To really brighten up the lights polish the reflectors with a damp rag and some jewelers rouge. Or have them remirrored if they are really bad. For night parades?
Gordo-SD
Don L C
02-17-2005 12:33:58
Got mine at NAPA auto store.
RustyFarmall
02-17-2005 08:16:10
I have purchased those from both my Case-IH dealer and from NAPA. Be sure you get actual headlight bulbs, taillight, turn signal, and parking lamp bulbs Will fit, but those are neither as large in physical size nor are they as bright.
CNKS
02-17-2005 07:45:10
OEM Tractor Parts has them -- however the numbers are 1129 and 1156 for 6 and 12 volt respectively. These are generic numbers, NAPA or others should have them.
RustyFarmall
02-17-2005 08:31:33
 Re: IH lights in reply to CNKS, 02-17-2005 07:45:10
CNKS, I believe those numbers are for tailight bulbs. The 6 volt headlamp bulb is an 1133. I also looked at a bulb that is a 12 volt, can't find any numbers except for 12V 32 CP. CP is for candle power.
CNKS
02-17-2005 19:32:46
 Re: IH lights in reply to RustyFarmall, 02-17-2005 08:31:33
You could be right, but the numbers (1129,1156) are in the OEM Tractor Parts catalog, they list the same number for both, and they would be the same for the main bulb. The small ones are different. My H parts book does say that either the head or taillight bulb is 1133 as you say though. Perhaps we are both right, maybe the candle power is different for the 1129.
little john
02-17-2005 07:10:38
I got 12 volt bulbs from a local auto parts store. I would think you can get them from NAPA, etc.
