differential oil level for farmall M
ianf
02-17-2005 14:19:01
CAN SOMEONE TELL ME IF THERE IS AN OIL LEVEL PLUG FOR THE DIFF, ON AN M, OR IF NOT, HOW TO CHECK LEVEL. ALSO HOW MUCH OIL DOES IT HOLD AND WHAT GRADE.
Dave Wilguess
02-17-2005 22:15:35
 Re: differential oil level for farmall M in reply to ianf, 02-17-2005 14:19:01
I just did mine it held a little over 13 gal. and as said befor a 1/2 plug to check the level 80/90 gear oil but they recomend 90 weight menerial oil for foming but the bull gear in that dif. will not spin fast enought to cause foaming in the newer gear oils.
farmallhal
02-17-2005 19:26:36
Owners manual says 13 gallons of SAE-90 oil for the transmission and differential for temperatures above zero. For use in temperatures below zero add two gallons of kerosene into the transmission case. After adding kerosene operate the tractor until the mixture is thoroughly warm and then drain down to the level plug.
captaink
02-17-2005 15:32:09
On the clutch side of the rear end casting just below the clutch rod, there is a 1/2" pipe plug. You have the correct level of rear end lubricant when it starts to run out of this hole.
I'm not sure exactly how much it holds without looking it up, but seems to me is about 13 gallons.
