AV manual to hydraulic
carman
02-17-2005 15:42:22
my AV as a power steering pump to run the lift I like to put touch control on it, can this be done,what parts do I need,and how much work is it do this job, My AV is a 1945 it had vac lift, the guy I got it form put the steering pump on it thanks carman
BIG JOHN
02-17-2005 18:29:03
 Re: AV manual to hydraulic in reply to carman, 02-17-2005 15:42:22
You will need everything from a working Touch Control except for the pump. These are found on all Super A's and C's and SC's.
You will also need to find out the capacity of the power steering pump that you have, gpm and psi You probably have enough but you should check it out before you invest in all the rest of the things you will need.
GOOD LUCK
