Live PTO
mark k
02-17-2005 21:11:49
Hello,
A friend and I went in together and bought a I think a 300 U and I was wondering if the live PTO can be put on my 350 U? This PTO has the long lever that looks like it could be engauging clutches, mine is the standard push you through the fence model. Thanks Mark
mark k
02-18-2005 20:52:44
 Re: Live PTO in reply to mark k, 02-17-2005 21:11:49
Thanks for the responces. Have a great one. Mark
Aces
02-18-2005 07:28:12
Mark Never knew a 350 to have transmission diven pto if that is true that your 350 has transmission drive pto then the answer to your question is no.
RO
02-18-2005 06:39:27
You probably know this, but to avoid the "push you through the fence" experience, install a $60 overiding PTO drive on your PTO shaft. The overiding PTO is available at most any store handling PTO parts/pieces.
JLE
02-18-2005 05:31:35
You will be able to switch IPTO form 300 U to a 350 U without any thing internal being done.
JLE
02-18-2005 05:34:00
 Re: Live PTO in reply to JLE, 02-18-2005 05:31:35
I stand corrected you can't go from standard PTO to IPTO with changing internal!!!
r4etired
02-18-2005 04:09:09
I think you would have to start changing at the flywheel as that's where the LPTO starts.
