Farmell H to 300
Gary Duff
02-18-2005 05:55:26
I have a freind who has an H that he would like to make stronger,he wants to know if the pistons and sleeves from a 300 will fit in an H engine,Thanks,Gary
THEkyroastnear
02-19-2005 23:03:00
 Re: Farmell H to 300 in reply to Gary Duff, 02-18-2005 05:55:26
i believe the super h & 300 have the same engine else-wise i agree with rusty
RustyFarmall
02-18-2005 06:54:33
I am sure that the block will need to be bored before the 300 sleeves will fit, not impossible to do but may not be worth the added expense. A better option would be to install the H overbore sleeve and piston kit. The overbore kit, with high compression pistons will make a big difference. If this still is not enough then you can mill a little off the head, increasing the compression even more. There are a lot more things you can do, but Space doesn't allow me to list all of them. Do what you want but I don't think I would bore the block if it were mine.
