Order Farmall Cub Parts Online
Farmall Cub Pinion Shims
Oldironcrazy
02-18-2005 08:28:04
Does anyone know how many shims need to be placed behind the bearing retainer that holds the pinion shaft in the trans? Mine has 2 thick and one thin
behind it now. Just wondering if this is right.
Thanks, Oldironcrazy...
Ida Red
02-18-2005 21:00:36
 Re: Farmall Cub Pinion Shims in reply to Oldironcrazy, 02-18-2005 08:28:04
Have a good lot of red Cub IHC parts.Red
the tractor vet
02-18-2005 09:26:44
When you set a pinion to ringgear the amount of shims differs from one to the next and if you are just changing bearings then reinstall what you removed this should keep things close .
Oldironcrazy
02-18-2005 17:41:19
 Re: Farmall Cub Pinion Shims in reply to the tractor vet, 02-18-2005 09:26:44
Hey Tractor Vet. Thanks for the comeback but can you tell me what the proper setting is for ring and pinion depth and how to check it? I know the backlash is adjusted by shimming the bearing cups on the sides of case but i'm not familiar with pinion depth. Thank you.
Rudi
02-18-2005 18:52:19
 Re: Farmall Cub Pinion Shims in reply to Oldironcrazy, 02-18-2005 17:41:19
third party image
If you check the link below, then go to the Blue Ribbon Service Manuals, then to the GSS-1411, you will find the answers to your questions.
The Cub Manual Server has all kinds of info on it.
Hope this helps
Oldironcrazy
02-18-2005 19:55:11
 Re: Farmall Cub Pinion Shims in reply to Rudi, 02-18-2005 18:52:19
Hey Rudi thanks so much for the link!!!!
