'Nother Wonderment
Allan in NE
02-18-2005 17:56:18
Okay then,
What"s the deal on the loop on the end of the PTO actuator lever? Our "tother "53 H had an "L" shaped rod with no loop to it. ??
third party image
John *.?-!.* cub owner
02-19-2005 17:45:48
 Re: 'Nother Wonderment in reply to Allan in NE, 02-18-2005 17:56:18
We had a 41 and a 52 both with the loop. had a peice of baling wire tied in a loop for hanging extra more sections from them. Ah, memories.
John M
02-19-2005 14:52:20
The L shaped one is most likely the belt pulley rod.They both are about the same length,so if soemthing happened to the looped rod for the pto,someone just used the belt pulley rod.
Allan in NE
02-19-2005 16:09:30
 Re: 'Nother Wonderment in reply to John M, 02-19-2005 14:52:20
Well,
'Cept our H and M both came down off the truck, brand spankin' new, with the "L" shaped PTO levers.
Dunno,
Allan
kjm
02-19-2005 14:32:40
Allan, You need to tie a trip plow rope on it and sooner or later it will be bent at a 90. LOL KJM
Farmallkid From Ont,
02-19-2005 13:56:07
Maybe the guy bending them wasn't as strong as he was the day before, I have never seen a L shaped one.
Harold H
02-19-2005 08:54:12
No rhyme or reason or serial number break as far as I know. Some are one way and some the other. My 51 has loop.
Harold H
Allan in NE
02-19-2005 09:54:26
 Re: 'Nother Wonderment in reply to Harold H, 02-19-2005 08:54:12
Hi Harold,
I think you're right; lot of this stuff just doesn't make any sense at all.
Lots of guys are talking about a center shock on the Ms. I've never laid eyes on one. Go figure.
Allan
P Backus
02-18-2005 20:56:08
For what it's worth, I believe my '49 H has the closed loop as pictured. Works good for me!
Paul
Redmud
02-18-2005 18:23:45
Allan, I have no idea. My 42 has the "L". My 52 has the loop. I do no that I like the "L" best. cause when the knuckle joints hurt, two fingers are better than one.
Redmud
Allan in NE
02-18-2005 18:28:55
 Re: 'Nother Wonderment in reply to Redmud, 02-18-2005 18:23:45
Red,
Plus, don"t forget that you can hang your cresent wrenches on that "L". :>)
Allan
Redmud
02-18-2005 18:39:40
 Re: 'Nother Wonderment in reply to Allan in NE, 02-18-2005 18:28:55
Allan, mine has a 15 inch hung on it now, along with a 7/16 9/16 and a 3/4 boxend. And I like your new seat, it looks outstanding.
Redmud
jayw
02-18-2005 18:12:35
Didnt they have a problem with earlier pto ,s breaking gears and changed the style around 52 or so , My 41 has the Lshaped lever but the PTO housing is only sticking out 3 inches and the nieghboors 52 has a PTO housing that sticks out about 7 inches and has the lever that you have pictured.
