farmall b Block
G. Allen
02-19-2005 15:28:24
Idiscovered at noon today my B has a cracked block Iwould like to keep tractor for sentimental value can anyone help me
G.Allen
02-20-2005 06:56:10
 Re: farmall b Block in reply to G. Allen, 02-19-2005 15:28:24
It is cracked on top of the deck just behind first water jacket around #2 liner allthe way back to just in front of #4 liner
Dave BN
02-20-2005 05:12:34
Bet it's cracked behind the carburetor. I have seen many of the repaired in that area. It should be fine once repaired.
Bill Geer
02-19-2005 18:50:02
I have a A with a patch that runs front to rear. about 5.5 inches wide. 3\16 thick and a lot of 1\4 inch screws. rite behind the carb. Dosent leak water, and runs good. Bill
John *.?-!.* cub owner
02-19-2005 17:37:53
As RAW said, it depends on where it's cracked. B blocks are wet sleeve, so it can live with some cracks.
RAW in IA
02-19-2005 17:35:44
Depends on where it is cracked, it is possible to repair some. My son' F-20, which was my Grandpa's, has a repaired block. It froze up many years ago, and when my youngest brother fixed it up, he had a cousin weld it up. It had pushed out on one side, but didn't get into anything important. He did a real nice job of it and it is holding good.
james williams
02-19-2005 17:24:31
Knighten farm supply 304-876-2648
