sleeves pistons
Rich Grifdfin
02-19-2005 19:13:03
Does M & W still make these for a 263 gas? I like their 4 ring pistons.Are there others that make a 4 ring piston if they are not available at M & W.?
ChadS
02-20-2005 07:07:19
 Re: sleeves pistons in reply to Rich Grifdfin, 02-19-2005 19:13:03
Rich, if you are talking about the 263 in the 560-706, there is a 4 ring piston still available. Should be the same rings used for the M&W, as the stock set would. I make high compression pistons for the C-263 gas. And used in stock bore. Can be done as an inframe overhaul,,,, they would be 3 ring pistons though,,, Hope this helps,, ChadS
