Tire, Rim Size
bog
02-21-2005 17:21:50
Hey guys i have a 9 inch wide 38" tall rim, will 11.2 38"s fit a 9 inch wide rim, or is my rim not wide enough
CNKS
02-21-2005 17:42:36
 Yes in reply to bog, 02-21-2005 17:21:50
OEM rim sizes were generally 1 inch smaller than the old tread width. 11.2-38's are identical to the old tire designation of 10-38, so the answer to your question is yes, PROVIDED you measured the rim width properly. The width does not include the lip that extends past the tire. I say this in case of the remote chance you actually have an 8 inch rim that measures 9 inches including the lip -- size should be stamped inside the rim anyway.
randy hall
02-21-2005 17:39:42
 Re: Tire, Rim Size in reply to bog, 02-21-2005 17:21:50
yes that will work just fine.
