m and super m carberator the same?
Kevin Farmall
02-21-2005 18:13:42
I need to know if a m carberatoris the dame as a super m carb, especially the bowl. I drill out the main jet hole on my super m carb by mistake now I looking for a stock bowl just wondering if the bols are the dame?
DWV
02-22-2005 05:13:08
 Re: m and super m carberator the same? in reply to Kevin Farmall, 02-21-2005 18:13:42
SM bowl choke lever is located engine block side
of bowl.M outside,they will bolt on each other
though.As CNKS pointed out you could have metering
problems.
CNKS
02-21-2005 18:28:45
They may appear to be the same, but the jets are different. If the Super M carb (I don't have one) is adjusted the same as the Super H, max power is obtained with the main jet screw 5 turns out, as opposed to the M which is 1/2 turn or so open after it runs smooth. I would guess the bowls are the same, but you will need the Super M jet. Someone with both parts catalogs needs to compare the numbers to be sure. On the other hand, why don't you just replace the jet (if you can get it out)
