IH 260A Series Pay Hoe
Dana Padgett
02-22-2005 18:48:47
With front tires off the ground, they barely turn, so I pulled line off to hydrolic cylinder and with tractor running I turned steering wheel only to see small amount off fluid sputting out.
All other hydrolics are fine!
Is problem in steering box or ???? and if it is the box, what am I looking for inside specifically to be the problem? Please give me an idea where to start!
JLE
02-23-2005 16:21:11
 Re: IH 260A Series Pay Hoe in reply to Dana Padgett, 02-22-2005 18:48:47
Does the swing work on the backhoe? They use the same pump, I have 2500 that has same system, when it gets a little warmer I have replace it's P/S pump.
JLE
02-23-2005 16:20:30
Does the swing work on the backhoe? They use the same pump, I have 2500 that has same system, gets a little warmer I have replace it's P/S pump.
Dana Padgett
02-23-2005 17:30:24
 Re: IH 260A Series Pay Hoe in reply to JLE, 02-23-2005 16:20:30
JLE, Thanx for a super fast response...
As a matter of a fact it don't, unless I changed feedline from controls, You hit the nail dead on!
So tell me this JLE, where is the pump located and is there a couple of steps to take...
I've done auto mech, not much on heavy equipment...if I had a couple pointers here, maybe I can get it going.
Thanx so much JLE...A big help...bless ya!
