International power unit
AndrewD
02-23-2005 11:04:23
A friend gave me a international PDGC-40. i found another one, but its a PD-40. does anyone know what the letters mean? does anyone know where i can find some information on this power unit or where i can get parts?
thanks
Martin Caldwell
02-24-2005 04:30:20
 Re: International power unit in reply to AndrewD, 02-23-2005 11:04:23
I would like to buy a PD 40 is one of those for sale?
Harold H
02-23-2005 17:11:37
My 1940 IHC General Catalog does not make any mention of the GC on the PD-40 power unit. They list lots of variations and options, any of which might have been identified by the GC on the serial number. The PD-40 was rated as 62.5 HP fully equipped at 1250 rpm.
Harold H
Bob M
02-23-2005 11:44:10
Andrew - The PD-40 is a WD-40 tractor engine (start-on-gas diesel) set up for use as a stationary power unit. I presume that "P" is for Power Unit and "D" is for diesel. But I have no idea the significance of the "GC" in yours. Does it perhaps have a special power takeoff/transmission? Or is it set up as a prime mover for generator (special governor and flywheel housing)?
AndrewD
02-23-2005 16:51:37
 Re: International power unit in reply to Bob M, 02-23-2005 11:44:10
This one is different from other power units that i have seen. it has a long cast iron frame-the other one just had 4 legs to hold it up. the top half of the clutch housing is missing-looks factory and there are bolt holes to bolt the top back on. its longer than the other pd 40 i saw. it is setup right now to run a sawmill-has a homemade hand clutch and a big belt pulley. hope this helps. thanks
Bob M
02-23-2005 19:20:34
 Re: International power unit in reply to AndrewD, 02-23-2005 16:51:37
Can you post a photo? It sounds kinda interesting!
AndrewD
02-23-2005 20:17:39
 Re: International power unit in reply to Bob M, 02-23-2005 19:20:34
might be able to get some pics this weekend.
