U6 power unit
Joe T
02-23-2005 11:12:34
does anyone know where I can get a picture of a u6 power unit. any info on this unit would be helpful Thanks, Joe
Bob M
02-23-2005 11:49:11
 Re: U6 power unit in reply to Joe T, 02-23-2005 11:12:34
Punch below for a shot of a U-6 and U-2 spotted at a recent show.
The U6 is the Farmall M and IHC W6 wheel tractor (also the T6 crawler...) engine set up for stationary use. It's capacity 248 cubic inches, and is rated in the area of 30 - 35 HP depending on govenor setting.
colekicker
02-23-2005 18:55:10
 Re: U6 power unit in reply to Bob M, 02-23-2005 11:49:11
I might have to argue the 30-35 hp rating. I have 3 U-6's and their max rpm is 1650 like the Super M.
Bob M
02-23-2005 19:18:23
 Re: U6 power unit in reply to colekicker, 02-23-2005 18:55:10
Indeed!
But keep in mind the advertised or "rated" HP also depends on the intended appication.
A stationary engine rated at 40 HP max for intermittant duty (like on a sawmill) might only be rated for 30 HP (= 75% of max capacity) for continuous duty as on an irrigation pump.
Or the same engine running a 6 pole, 60 hz generator may be rated at only 25 HP continuous duty at design speed (which = 1,200 RPM for this situation).
CNKS
02-23-2005 11:46:59
Pictures are in the M/6 series service manual, I don't have a scanner, what info do you want?
