460 farmal Power sterring
Eric Hicks
02-23-2005 14:58:59
I'm restoring my 460 and ran into a problem with the power steering. It will steer to the left good but, to the right it's hard to steer. It has a swartz wide front and I have the whole front end separated from the tractor and I can't figure it out. Please help. You can email or if you leave number I would prefer phone conversation. Thanks
Aces
02-24-2005 07:20:03
 Re: 460 farmal Power sterring in reply to Eric Hicks, 02-23-2005 14:58:59
Eric the steering valve is in the front bolster and the steering shaft must move in and out a little. So if it only can move one way it will only power steer one way. the u joint at the bolster housing has splines that is where it should move if the are rusted tight or pined because the splines are bad then the shaft clear to the steering wheel must move there is a set collar on the shaft under the hood that could be set to tight to the cast housing at the steering wheel, or the bearing at the clutch is tight.
Jim J
02-23-2005 17:14:33
Email me I have some questions to ask you.
