H not getting fuel
GNB
02-23-2005 18:39:37
I have a 41 H that will run fine for a while and then sounds as if it is starving for fuel. I have the replacement soft fuel line on it. I can lift the fuel line up above the carb before the tractor cuts off and it will begin to run fine again. I just started having this problem recently. Is the float hanging? Thanks in advance for your help.
GNB
klondike carl
02-24-2005 17:00:29
 Re: H not getting fuel in reply to GNB, 02-23-2005 18:39:37
Try taking sediment bowl off and blowing into
gas tank with air gun. Take fuel cap off first.
If that don't work try steel fuel line.
Wayne Swenson
02-23-2005 19:39:09
It seems you have diagnosed your problem yourself. If the engine runs when moving the fuel line, I suggest that the line has an internal deterioration problem.
Why not replace the line with steel as it was originally? Purchase a section of precut brake line (it is flared with threaded nuts installed) at NAPA or other auto supply and gently wrap it around a 3" container to get the proper shape. Copper tubing will also work; however, it can work harden and crack causing a fuel leak. If you are not using the tractor as a daily worker the copper will most likely be just fine.
