Re: Engine Gunk (H)
John M
02-24-2005 04:37:16
paleriders suggestion is what I have done more than once.Also remove the lifter cover and do that area as well.What I usually do is,after that first scrubbing,I fill it up to level with ever how many quarts it takes of non detergent minus one quart,replacing it with detergent oil,run it a littlew while and then chenge the oil with two quarts of detergent and so on and so on until I finally have all detergent oil in,changing the filter each time.It can get expensive doing that so I use cheapoer oil until I gettop the final stages,and if its not to awful bad inside I use the filter through two changes.
