Order Farmall Cub Parts Online
CUB WON'T START!!
JERRID
02-24-2005 07:13:41
MY CUB WILL NOT START I HAVE PUT A NEW CARB ON AND A NEW SET OF POINS AND ROTOR. I AM GETTING FIRE AND IF I HOLD MY HAND OVER THE BREATHER IT WILL RUN FOR JUST A SECOND. A SMALL AMOUNT OF GAS DRIPS OUT OF THE CARB WHEN I DO THIS. PLEASE HELP ME I DONT KNOW WHAT TO DO!! THANKS
El Toro
02-24-2005 07:32:33
 Re: CUB WON'T START!! in reply to JERRID, 02-24-2005 07:13:41
Loosen the tube fitting at the carburetor to see if a good flow of gas is here. If the flow is ok your problem is in the carburetor. If you have just a trickle of gas or just a drip you have blockage in the fuel tank, gas line or sediment bowl. It could be dirt or a gummy deposit from unleaded gas. You do not want any dirt or gummy
deposit to get into that new carburetor. Disconnect the fuel line at the carb. If you have just a drip, blow some air through the fuel line.
If you get fuel to flow freely after doing this
your gas tank probably needs to be cleaned. Hal
JERRID
02-24-2005 08:14:08
 Re: CUB WON'T START!! in reply to El Toro, 02-24-2005 07:32:33
I ALSO ADJUSTED MY GOVENOR AFTER I WAS HAVING PROBLEMS I DID IT EXACTELY LIKE THE BOOK SAID BUT IT WHEN I TRIED TO START IT IT SOUNDED DIFFERENT??
El Toro
02-24-2005 11:35:21
 Re: CUB WON'T START!! in reply to JERRID, 02-24-2005 08:14:08
You should get the engine running before you make adjustments on the governor. It may not have required any adjustments. Find the fuel problem
so you can get the engine started. Hold your hand over the intake of the carb and see if you feel any suction while the engine is being cranked and if the engine starts. You'll
need a helper to do this. The first thing is to see if gas flowing to the carb. Loosen that gas line. Hal
