Farmall 200 6 to 12volt
jms/Farmall 200
02-24-2005 07:48:11
Does any body know where I can buy a 6 to 12 volt conversion kit to fit a Farmall 200.
I have had a lot of electrical problems
Farmall 200 Maine
jms/Farmall 200
03-01-2005 15:27:08
 Re: Farmall 200 6 to 12volt in reply to jms/Farmall 200, 02-24-2005 07:48:11
Thanks for the input , what I think is to put new wiring on it. When I put a new voltage regulator on it last year I noticed several places where the wire was bare.What about the places I couldnt' see...
Any advice on where to get the wiring? Any one have experience on what to look out for, or is it pretty straight forth? Also I noticed my ground strap is frayed and old looking,would this be limiting the system and not allowing the battery to charge?
Farmall 200 in Maine
JOSSETTE
02-25-2005 19:04:34
did your Q get aswered?? I have an easy to follow wiring diagram if you need it or any Q's
click on my name if any Q's
Dave_Id
02-24-2005 09:20:08
You can buy a single wire Delco Alternator at Napa, but are you sure these problems won't continue? Maybe you just need fresh wiring, and heavy battery cables that are neccesary for a 6 volt system. Your 6 volt starter will run off 12 volt, you will need to switch to 12 volt bulbs, and reverse the wires on amp gauge if you go to negative ground.
CLIFF
02-24-2005 10:30:11
 Re: Farmall 200 6 to 12volt in reply to Dave_Id, 02-24-2005 09:20:08
In addition to what dave said, You will also have to change the wireing at the coil (Pos wire to Neg And Neg to Pos)wen you go to NEG ground, And run a resitor(To reduce voltage for a 6V coil) from tractor wireing to the coil. CLIFF
