RE; 350 utility; need help with points and conden
Brooks
02-25-2005 17:01:43
My tractor has been converted to 12 volt with the exception of the points and condencer; thought someone would know about it ; I need to switch it over to 12 volt but was wondering if I could just leave it the way it is
Brooks
02-25-2005 18:32:00
 Re: RE; 350 utility; need help with points and co in reply to Brooks, 02-25-2005 17:01:43
Hey Thanks Guys!! you've been alot of help to me
r4etrired
02-25-2005 18:21:06
Brooks,normally when a tractor like yours is converted to twelve volts there is a resistor installed 12 volt to 6 volt ahead of the coil Thus keeping the ignition system original.This was still used on the 46o-560 series. Check an see if you have this resistor, Most of them were mounted close to the coil.Also on the 460 and 560 there was an additional contact on the starter solenoid to provide 12 volts to the coil while the starter was being used the switched back to to the resister when the starter button was realeased,You can run 12 volts to the coil but the points will be very short lived, The factory resistor was white ceramic about 2.5 in long.
B Watson
02-25-2005 17:55:37
Your points and condensor don't really care if your 6 or 12 volt, just don't leave the key on.
PAULIH300
02-25-2005 17:09:21
Leave it,or install a Pertronix electronic module.
