Super AV---- Front Rims
Jonn
02-25-2005 17:06:44
Pulled off the rims on my AV to paint. Problem is now I can't remember which side faced in. Seems to me the rim side with the valve stem was on the inside--not sure. Does it make a diff. on these rims or not? If so which way would be correct. The flange for bolts to go thru on the rims are shaped different on each side. So does it matter? Thanks for any info.
Ida Red
02-25-2005 21:28:18
 Re: Super AV---- Front Rims in reply to Jonn, 02-25-2005 17:06:44
Can yuou tell a fellow where he might get an original AV owner-operators manuel.
dr.sportster
02-26-2005 13:52:03
 Re: Super AV---- Front Rims in reply to Ida Red, 02-25-2005 21:28:18
Probably Walter Miller Syracuse ,NY advertises in Hemmings motor news.If anyone has original owners manuals for autos its him.He probably does tractors also.He avvertises to buy them also.
Novel Idea Guy
02-25-2005 20:08:01
The rims are designed to be mounted in any of four positions to get different tread widths. There is no one "correct" way. There are four. Unless you need a specific tread width, mount them in whatever way you think they look best. Frankly, I like them with the lugs on the inside of the hub, and the valve stems out.
Novel Idea Guy
02-25-2005 20:06:56
dr.sportster
02-25-2005 18:18:20
Only if the tire is on ;valve stem outside is all.
