hand brakes on F-20
Regular Willieh
02-25-2005 18:56:38
My boy bught me a hand brake for a 20. I already have on one it. Im wonderingif I can mount onew on th right side, thereby having han brakes on both sides? Thanks for the help..... .
Nebraska Cowman
02-26-2005 04:02:11
 Re: hand brakes on F-20 in reply to Regular Williehandle, 02-25-2005 18:56:38
yes, you can but you will have to pull the wheel, remove the brake drum and pull the shaft out. Is it worth it? Then if he bought you another lefthand lever you will have to do a little engineering to make it work. Now on the other hand if he bought you a righthand lever (yes, there is such a thing) you have a very rare item and must by all means install it.
James Herrman
02-25-2005 22:29:19
Why not????? ?? Our old F20 has a piece of pipe bolted on the right side. Been that way since the 1960's. Have at it. JIM
