Cultivators and drawbar
'49 Farmall
02-26-2005 10:13:34
I have two questions with respect to the drawbar and cultivator assemblies for a Farmall Super AV. First off, will a standard farmall A or super A drawbar for an AV dimensionally? In other words, can I buy a straight A drawbar, and then have the drops and other high crop brackets made up to make it work instead of holding out for a complete high crop assembly (If you happen to know of a drawbar assembly for an AV let me know :) )? Second question, I have the mounts for the midmount cultivators for my super AV and the spring attachment to lift them from the touch control assembly. Will the toolbars from regular a/ Super A cultivators fit these mounts and does anybody know of anywhere that sells the toolbars separately with the shanks? I am located in Connecticut and will possibly drive 2-3 hours for the right equipment. I also need a complete set for the rear as well. Thank you for your help.
Tom
